  • MS3/Extra 1.3 stable pour MS3
 #2840  par Manu
 09 mars 2014 13:15
Après 1 an de développement, la team MSextra (James Murray et Ken Cuvler) viennent de mettre à disposition la version finale du firmware 1.3 pour les calculateurs MegaSquirt 3, MS3-Pro, MS3 module et MS3 gold.
Principaux changements depuis la version 1.2.4
  • Support 'high-speed runtime' dans TunerStudio MS
  • Ajout de VSS3,4
  • Support high-speed shaft speed inputs.
  • Rotary trailing option change.
  • Generic PWM - different frequencies, variable frequency and 2D curve option.
  • Option for double-speed readback of SDcard data.
  • SDcard logging can be triggered by TPS/RPM.
  • Staged injection relay output.
  • Fuel pressure correction.
  • Alternator control.
  • High-Power Time Enrichment.
  • Remove "IAC cold position"
  • Oil pressure monitoring.
  • Generic sensors user-settable names.
  • MAF logger, engine logger.
  • VVT exhaust table can be retards.
  • Experimental Long Term Trim.
  • Basline ethanol% in flex.
  • Re-write over-run fuel cut.
  • Fuel pump PWM control.
  • Turbo car staging feature.
  • New page to display usage of all inputs/outputs.
  • Wheel-speed launch control.
  • Miata 36-2 wheel mode.
  • MAF sampling uses integrated averaging (voltage MAFs)
  • BMW S54 cam decoder.
  • Re-implement fuel and spark cut rev limiting.
  • Fuel pressure monitoring.
  • Swap phase on Viper Gen1.
  • spk/inj dropping testmode.
  • Fix 710.1deg tooth#1 angle bug.
  • Add sensitivity slider to closed-loop idle.
  • Add sensitivity slider to closed-loop boost.
  • Add Nissan VK56 support to QR25DE decoder. (untested)
  • Extend VQ35DE to support VVT (untested)
  • Add Hemi VVT (as VVT option)
  • Add poll_level_tooth (should allow Rover 4.6)
  • Add support for 36-2-2-2 VVT engines (untested) LH = main cam sensor, set VVT teeth=4
  • Chrysler 2.2/2.5 changes from MS2 (untested)
  • CAN outmsg support.
  • Harley "HD32-2" wheel mode and oddfire code.
  • Generic closed-loop PWM control.
  • Add engine shutdown feature.
  • Poll-level sync changes.
  • Calibration tables can be written over CAN.
  • Serial error checking
Plus quelques changements mineurs et corrections de bugs.
Vous pouvez télécharger ce firmware ici :
http://www.msextra.com/doc/ms3/files/re ... -1.3.0.zip
Assurez-vous de bien lire le fichier RELEASE-NOTES.txt inclut dans l'archive afin de connaitre les "GOTCHAS" lorsque vous mettez à jour un calculateur ayant un firmware précédent (typiquement 1.2.4, le dernier firmware stable pour MS3).
