Saxo VTS Base Map MS2/Extra
MessagePosté :11 mars 2019 15:23
par bweller91
I have previous bought a MS2/Extra which was running a Gt25 turbo and 182 Injectors.
I would like to adjust the map so I can run it on my standard 16V VTS engine if possible.
I have got the .MSQ map file from the ecu if anyone would be kind enough to take a look.
Re: Saxo VTS Base Map MS2/Extra
MessagePosté :11 mars 2019 21:46
Where is the msq ?
MessagePosté :12 mars 2019 08:51
par bweller91
MessagePosté :12 mars 2019 18:17
Advices :
Use "1st prediction" in ignition setting
set dwell to 2.9ms
Use more smooth on your lambda input
Your VE table is out of any scope. But I guess that you don't tune it for turbo ?
MessagePosté :12 mars 2019 19:41
par bweller91
Thank you for the quick reply, I will adjust the ve table the best I can.
It does not have a turbo just original standard engine.
MessagePosté :13 mars 2019 18:46
So you have to redo your tables axis to meet this
