Tu5jp4 Cr 12 timing ignition
MessagePosté :28 nov. 2020 10:52
Hello good day. new member passionate about the Tu5 engines, I have a saxo t16 and a 106s16 with high rate of atmospheric compression and both megasquirt
I am new to tuning MegaSquirt, I have some knowledge.
now i have a tu5j4 engine with cat 280 cams with iasa 12: 1 CR 78.50 mm pistons
I have a self-made ignition map, but I have some doubts
where can i find a clean msq ignition map run in an identical reliable configuration to have a good base of comparison
